I'm having a problem with my central heating. The radiators are intermitantly getting very hot and are not being regulated by the room thermostat (e.g. the central heating on the timer control unit is off).
I believe It is a fully pumped system:
Netaheat Profile 40e gas boiler
with a Honeywell 4073 3 way valve.
The problem seems to have started since returning from a few days away when the CH and HW controls were switched off
Am I correct in my assumption that these problems are caused by a faulty 3 way valve?
I ask as the valve head has been making strange noises and the problem seemed to have been cured the first couple of times by a sharp tap with a screwdriver handle.
Now having taken the cover off it seems that the motor is starting to stretch the spring but then letting it lose a bit of tensen while making "psst psst psst" noises as if its supposed to latch into a position with the spring under tensen but is not quite making it.
Is this the problem or am i just going off on a tangent???
Thanks for your help
Matt
Matt
