Update for the above, I have ran the system now with the Motor, Diverter valve and the thermostat on the hot water cylinder disconnected. Did notice yesterday that when the fuse blew, a spark jumped out of the timer switch ( Randall 103 mechanical timer) with the help of a couple of guys on here I've managed to source a replacement. In the meantime can anyone advise as to whether there is a simple test to do to eliminate the timer from the system as faulty before I purchase, they are quite expensive.
Regards Otto
If the heating system is wired correctely it is not possible for the pump to remain running when the spur fuse blows. are you sure that the fuse you refer to is the one for the electrical supply to the heating system?.
