Thanks for the posts PullerGas, yes that's along the lines of what I've been told. 10mm pipe, 8mm bore. I was hoping to go up to 15mm pipe, speedfit to allow water to the radiators faster and all going well they heat up faster (in theory, I realise there are other factors, happy for folk to point them out, more info is always better). Along with that fact, removing the acorn piping which may or may not last another 10 years means I know what's gone in and yes it may fail before the existing piping but at least I've more of an idea of its age and state.
My current plan is to
drain down the system, I fitted a drain off valve last year to one of the valves on the radiators downstairs as I had none to drain the system. I know where the filler tank is in the loft and will tie up the ballcock so it doesn't continue to fill.
1 by 1 I'll take a radiator,
Take it off the wall,
run the piping to the centre point of the radiator from the old manifold upstairs (not connecting).
Bring the pipes through the wall with the JG radiator outlet plate leaving plenty extra pipe to go to either side of the radiator.
bring the radiators outside and flush them through with mains pressure outside a good few times until they run clean
Re-hang the radiators through the plasterboard onto the brick, either with a baton behind the plasterboard or a proper fixing, they were all hung with self drill plasterboard fixings which don't take much to dislodge.
When the Radiators are hung solid, fit new Valves (not decided which TRV's to fit) these will go into a 90degree elbow compression fitting onto which the plastic pipe will connect (as per the image in my first post)
I'll repeat that for all the radiators that require to be rehung, all will be flushed.
Once complete I'll attach all to a new set of manifolds in the same location as the last and finally plumb back into the feed and return from the boiler.
I intend to have plenty ptfe tape and white jointing compound as required for the joints.
Once I've connected again, I'll refill the system from the filler, flushing it through the whole system and out once or twice to clear out anything left that I can get out.
Then refill for the last time with inhibitor.
After that, It'll be over to the plumber when I get one to fit a new boiler and tie into the manifolds with new pipework when the boiler is replaced. At this point I'd hope to have gotten rid of the hot water cylinder, the electric pump for the upstairs bathroom water feeds, the water storage tank in the attic, the central heating filler tank in the attic, the older still functional boiler in the kitchen and all the acorn 10mm piping in the house. The piping for water feeds in the bathroom upstairs was done a few years before we moved in with newer hep plastic piping so I do not intend to replace any of that, just have the new boiler plumbed into it.
If anyone wants to know why I'm getting rid of open vented and want a combi boiler, the reasons would be in the line of acorn piping and the reputation for it to cause failures or leak, the electric pump which causes a racket upstairs when you want water in the bathroom (baby on the way so would not be helpful), Almost instant hot water from a combi-boiler instead of trying to manage the timings for heating a tank of water (yes, that's laziness but my wife and I agree its just easier with 2 soon 3 kids and us), and really just because we can and its what we had before and it just worked.
Anyone who spots any flaws in my plan, feel free to point them out. Hoping to figure as much of this out before I start. Shopping list is being created so parts can be gotten in the month before's pay check in case it all goes wrong
Paddy
