Ceramic tiles on concrete floor?
SMG
31 Oct 2007
Manchester
My shower room floor is re enforced concrete, sat, I believe on polystyrene slabs, which are sat on a blue type plastic sheet, (Built 7 years ago). The concrete was covered with asphalt then tiled. My problem is that the floor is higher than the adjoining room floor, & I want it level. If I remove the tiles & asphalt, it will be at the level I need.
So, can I then re-tile onto the concrete floor?
Would there also be any problems with dampness or cold?
should,nt be as the DPM is still in place.
you will probably need to put a layer of screed on the concrete to give the tiles an acceptable /level surface to lay on.
you would need to ask this in the tileing section or building part of the forum, someone like woody would give you a more accurate answer, but good luck with it anyhow
I would love to, but I thought it would bring the height up too much, dont you have to lay the heating mat on insulation board, etc?
