Right the lever on the side!
This pushes against a lug on the quadrant so to speak. So if the valve was at CH only or mid position, the lever would be loose. But if the motor had been wound back by the reurn sping to the HW position then there would be resistance when you try to move the lever.
The purpose of this lever! well after draining down for whatever reason and with power off, you have to refill the system and to ensure water gets to both HW and CH sides you use the lever to hold the valve in the mid position. If you look carefully there is a latch in the slide so you can lock it in position. (unless of coarse you've broken it off like I did).
