CH pump overrun
Could what the OP wants be done with a priority hot water system where the CH valve is NO rather than NC?
I am not sure how it is wired, it is an S system I was told. Will have to take a closer look. Two questions are, should the pump continue to circulate when the thermostat is off? I think yes, pump should stay on for as long as CH is on. Also, should pump's overrun be routed to the CH as means of dumping excess heat from the boiler mass? I also think it should. But what if you are working on the CH and just want HW on? So maybe a dedicated "heat dump" circuit, like the bypass they have fitted but larger.
It is better to dump the heat into the hot water cylinder where it is useful.
It is a very simple circuit to add to the system but as stated above most installers will not understand it.
As said far simpler to add a bypass valve after the pump where it is meant to be. Probably not worth even removing the wrongly fitted valve.
