- Joined
- 7 Apr 2004
- Messages
- 30
- Reaction score
- 0
- Country
Hi folks,
Central heating system now seems to have a mind of its own. On the controler, CH is switched off, hot water on. It appears rads heat up when there is a call for hot water & the system appears to be ignoring controler & stat. settings.
Controler is an old Horstman Amethyst 7, no electronics, just timer switch & on/off switches for CH & hot water. Stat is a Drayton volt free, boiler is an Ideal classic LXFF, Satchwell sm 3203 minival valves.
Does this sound like a boiler circuit board problem? Would I be correct in saying it is the boiler that activates the circulator pump and valves when getting the appropriate switch states from the controler and stats?
Thanks for your help
Darwin
Darwin
