- Joined
- 4 Oct 2005
- Messages
- 555
- Reaction score
- 0
- Country
As one Luddite, I have aesthetic and other objections to the use of plastic, mainly based on the following:-
1. It sags and needs greater clipping/restraining.
2. In heating applications it expands and contracts with the varying water temperatures, this expansion is catered for by the 'o'ring joints, of which there are 3 per 'tee' fitting. There may be over 100 of there seals in a typical system, and if the mean time between failures is 25 years, there may be a first failure within 10 years, followed by regular failures every 2 years after that. If each leak means a patch of ceiling being replaced as in the case of block & beam construction then that's quite an irritation
3. The bore of plastic is smaller than copper, so it will have higher water velocities for the same heat loading, which MAY increase noise. The same can be said of the pipe inserts (eg Speedfit Superseal inserts).
The good points are it's speed of installation (should be reflected in a cheaper overall quote), the chance to use long sweeping bends (which are quieter in operation), and its best quality- it doesn't creak under floorboards when badly installed
Hope this has been seen as a balanced viewpoint, I've got no axe to grind either way.....MM
