Changed Downlights and now fuse blows when turned on
10 Jan 2008
Lancashire
Hi everyone,
I have just had a call from a friend who has asked for some help. 3 of his 5 downlights in his bathroom had blown and he couldn't get the lamps out. The downlights were old so he decided to buy 5 new ones. When finished he turned them on and the fuse blew. He is confident he wired them like for like but when he told me that one of the cables had some red tape I asked him to email me a photo.
GALLERY]
I know its difficult not knowing the full story (he lives 25 miles away so I couldn't just pop over) but this is what he told me.
There is a false ceiling and he thinks (?) the original ceiling rose has been replaced by a JB.
There is an extractor fan (no isolator), the extractor fan works off its own pull switch but this only works when the lights are switched on.
He thinks the light in the photo is the first one in the chain but I can't understand why both cables have red tape as one should be going to the next light, and also if the other one is a switched live it shouldn't be going direct to the light should it?
He also says there are no more cables inside the false ceiling.
I know there is scant info here and I said I will drive over in the morning but if anyone has any suggestions to what may have gone on I would be grateful.
OK, he can start by removing all traces of any tape anywhere near the lamp.
Theres no need for it at all, except the red identification on a black core to denote live.
Well, however that circuit has been arranged, how it's been connected in that photo is wrong.
Those cables are either:
A feed in and a switch cable
OR
Two switched feeds (ie switched live & neutral in each cable, plus cpc.
But connecting both conductors from each cable to a terminal is almost certainly wrong.
:oops: Or, as RF sugests, they may be SELV feeds.
I forgot to ask if they were LV or ELV but I assume that the fact he didn't mention transformers meant that they weren't.
It looks (sounds) like a right mess. I will take my tester over in the morning and try and sort it out.
Thanks for the help/advice
Steve (aka crafty).
Are you the downlighter king or what?
thinking of installing some downlighters soon - terracotta pots you say?
I agree, needs a visit to sort.
BTW, the typing on the picture makes a lot of assumptions. It says neutral with red tape but it may not be.
At this stage, ie without any real info, its a black wire with red tape.
Steve (aka crafty).
Only to keep insulation at bay.
Consider low energy versions.
