Can anyone help please, I'm a total novice & have read all the other posts, but want some advice as I'm being quoted rewiring as the solution @ £500?
I have a Mira Sport 8.5kw that I want to replace with a Mira Azora 9.8kw, the house is 12 years old & there is an RCD(it has 80 A stamped on the front of the trip switch in the fuse box?).
I'm not sure on the cable size (the grey cable attached to the inside if the shower measures approx15 mm) or how to find out what the fuse size is(it has B 40 stamped on the front of the RCD protected shower switch in the fuse box).
1) Could this just be swapped?
2) How do I find the Cable size?
3) How do I find the Fuse size?
