hi all,
I've just spent today removing an old broken storage heater from the wall in my flat...the bricks in those things are surprisingly heavy! Anyway - the storage heater solution didn't really work for me as it had pretty much cooled back down by the time I get home from work - in it's place I'm planning to put a basic electric, hang on the wall fire along the lines of this one.
primarily, I just wondered if there is any reason why I shouldn't just wire it into the same dedicated switched socket that the storage heater was connected to - it's connected to a sangamo dial timer which was set up to take advantage of off peak electricity for the storage heater.
Can I just change the dial timer to effectively always be on, and just use the switched socket to control when I want the fire on?
It seems straightforward in my head, but there's still some niggling feeling that the timer should be removed from the circuit entirely or that I'll end up using electricity unnecessarily somewhere!
The timer is a Sangamo Q345 by the looks of it, and looks a bit like this, but in a case.
this might be a basic question but I'd really appreciate any guidance!
thanks,
Mark
thanks,
Mark
