- Joined
- 27 Jan 2008
- Messages
- 25,285
- Reaction score
- 2,956
- Location
- Llanfair Caereinion, Nr Welshpool
- Country
I have an older but similar charger. It expects batteries to be flat when inserted and runs for a set time after which it switches off.
In the main the output of the charger is not enough to damage batteries.
I had one of these
got it from a radio rally and these Delta V chargers nearly always charge each cell individually. But do cost around £20.
However I have some old faulty cells and one destroyed the charger. It did last a couple of years first and it did do a good job but these also have a safety system built in to stop damage when a cell is inserted the wrong way around. This safety system also means it will not charge cells which have been over discharged. So you still need one like yours to charge up cells which have been over discharged.
In theroy we should stop using a cell when the volts drop below 1.1 volts but in practice we often will use a cell until the appliance stops working which is likely well below 1.1 volt per cell.
So although in theroy using a Delta V charger is the answer in practice it's not really worth the hassle and you just accept the cells will not last as long and with Delta V.
For me I was using with a flash gun which stopped running well before the battery became over discharged so the Delta V worked well giving me six sets of batteries but for my wife who leaves batteries in items until completely flat it often refused to charge the batteries until they had been in a cheap charger for a few minutes first.
For most people the charger you have is good enough. Some want maximum output and maximum life from their batteries and for them it is worth the money for a delta V charger.
I had one of these
