You put to me that PIR, PUR absorbs water, I reply with comments that I am unaware it does , you then pass over this with further questions ignoring some of the central issues.
I believe it does, but I'll find out - I've got a few odd bits of 50mm Kingspan - I'll immerse some in water and see what happens.
Before demanding further info from me, how about giving me some details about the leakiness of foams when I have said I am unaware that this is correct ?
They definitely do lose gas, with a concomitant drop in R-value, and I believe that BS EN 13165:2008, the standard for thermal insulation products for buildings - factory made rigid polyurethane foam (PUR) products specifies that the advertised values are to be the ones that apply after X years.
Hence my comment, because if you're basing your belief that they can't allow water vapour through because they are closed cell, and if they did that would mean that the blowing gas would escape then....
But as I say, I'll give it a try. Probably not very scientific, but might tell us something.
In passing I note that on Celotex's Technical FAQs page it says
Celotex is not suitable for use in inverted roofs (protected membranes) as it must remain dry at all times.
and
Celotex can be used below the damp proof course (DPC) providing there is a clear cavity. If there is any likelihood that it will be in wet conditions, it should be protected by a damp proof membrane (DPM).
which indicates some sort of susceptibility to moisture.
As regards the foil on the boards, can you quote me anything definitive ?
Can I recess my downlighters into Celotex?
No. Downlighters should not be recessed into insulated ceilings as they penetrate the vapour control layer (VCL)
and
How to avoid condensation risks?
Condensation in buildings is controlled with a variety of methods.
• Vapour Control Layers
A vapour control layer is a material with a high resistance to the passage of water vapour. This might be a foil faced insulation board (like Celotex) or a polythene membrane.
The principle is to prevent moisture in the air from reaching the cold side of the insulation, where it could meet a cold surface and condense.
I've not looked at other makers sites, but all the PUR/PIR products are broadly the same.
I have not found anything, which is a reason for my "belief" because a company with a good sales-argument will make sure it is prominent in sales-literature.
It is prominent, and clearly spelled out, so if it was b******s wouldn't it be widely challenged, and/or wouldn't there be companies selling competing products at lower prices because they didn't have a foil layer, explaining that such a layer was actually made of snake oil?
