Why what have I done?
Someone has to bring you to book.
You can, nobody will stop you. The problem is: will you do it right? For one thing, these are extremely sensitive and fragile instruments that go off the zero point easily. Secondly, they need checking and calibrating every year. The oxygen and CO sensors erode and will give completely wrong readings after a while, at which point they need replacing. Cost depending on spec from about £80 to £300..... WHY CAN'T I DO THIS?
Technically, you are not allowed to charge for that in money OR in kind without being a RGI....am also prepared to use my analyser on my neibours boiler too along with a nominal charge of £10 ,if i find CO/CO2 ratio exceeds action level then obviously time to call a RGI.
Another good attempt at the dickhead of the week award.many vulnerable people can no-longer pay for a full service due to rising bills. Better a bit of a test than none at all eh?
Oops, did you go into the wrong alias son?I do , although it seems you don't.It's obvious you didn't know what you were posting joe,.
Phew, that's me off the hook then, BenI nominate Joe for official "most ignorant poster on the forum" status.
The analyser needs at least annual calibration, AND correct zeroing, AND correct operation.What evidence do you have that the readings would be wrong?
