- Joined
- 11 Jan 2004
- Messages
- 45,886
- Reaction score
- 3,518
- Country
Rewire in MICC.....
Yes, I'm sure that's what he meant but, as I said/implied, if one simply re-wired, without mechanically protecting the new cables and/or 'definitely' getting rid of the rodents, then there could be newly-damaged cables 'a day or three after' the rewire!I think all he is saying is that by simply repairing what can be seen means there could still be damaged cables left.
They can, but it's an important part of the equation, since 'e-wiring' alone is not enough.Unless this is a thatched property, rats/mice can usually be got rid of.
I don't think anyone is saying to keep rewiring rather than solve the rodent problem, no one's hinted at that I'm sure.Yes, I'm sure that's what he meant but, as I said/implied, if one simply re-wired, without mechanically protecting the new cables and/or 'definitely' getting rid of the rodents, then there could be newly-damaged cables 'a day or three after' the rewire!
Having said that, one had to consider practicalities. Mine is a very large house and, on a couple of occasions over the few decades I've been here, I have become aware of rodent damage to cables - and, if I had undertaken a total re-wire on each occasion (in case there were unseen rodent damage to other cables) I would probably have needed a 'second mortgage'
Kind Regards, John
Probably not, but someone certainly suggested a re-wire without any mention/hint of the need to also solve the rodent problem (albeit perhaps because he thought that was 'obvious').I don't think anyone is saying to keep rewiring rather than solve the rodent problem, no one's hinted at that I'm sure.
... and that uncertainty will, of course, exist for decades to come, even if everyone started installing MF JBs when they should have done..... A problem has been found with junctions using screwed terminals: over time the pressure of the (hard metal) screw terminal on the soft copper conductor reduces and can cause a high resistance joint. This can mean heating up, circuit failure, potential for fire… This can happen over a long period of time. Years after you may have moved out. A future electrician -trying to find a fault - will not know if there are hidden junction boxes, or where they may be hidden.
Again, whilst that might well be theoretically true, I wonder how often problems due to this are actually seen in practice.A big problem is poorly machined screws with too coarse a thread, they dont bind properly and come loose.
I have had the screws come loose on the 12V halogen units I fitted a few years ago, quite a few have had multiple tightening.Again, whilst that might well be theoretically true, I wonder how often problems due to this are actually seen in practice.
Kind Regards, John
However, if there is to be a re-wire, it should obviously be preceded by solving the rodent problem..
Kind Regards, John
That's true, but 'in the past' is a lot further away than most people might imagine.Back in the past there was no restriction on use of junction boxes (with screw terminals) and millions are installed where they cannot be reasonably easily accessed.
