Hi,I want to have my external chimney stack removed and roof tiles/timber work extended to cover the gap,due to the chimney leaning and leaking water around the flashing.
Some points.
1,the chimney is not used and never will be.
2,chimney is on detached side of house (not shared with any other property).
3,chimney breast removal in loft just to underneath roof level.
Do i need to inform the local council (not in a listed building or anything special like that).?
Do i need council building control to be involved,my builder says no as he is removing brickwork and the existing what is left of the stack will still be in place and no steel/gallows involved.
Thank you in advance and i am happy to add more info that will help.
James.
Some points.
James.
