16 Nov 2024
I’m not sure if i’ve put this in the correct thread, sorry if not.
I am in the process of buying a house and the rear chimney has been completely removed sometime in the past however, the front chimney remains and it has been left like this in the loft (image attached). Does anyone know if this support is done correctly or is this likely to be a problem to the structure of the house?
We have raised the questions with our solicitor regarding building regs as advised by the surveyor but i just wondered if this is done correctly or is it likely to come back as an issue and delay things.
Thanks in advance!
The picture looks like an exam question for surveyors. Wouldnt it be easier to remove the flue liner and the rest of the bricks which don't appear to be supporting anything else structurally. I assume the single brick pier is resting on a structural wall below.
Thanks for your reply. The picture is screenshotted off my surveyor report. So it appears the stack was removed but then the owner decided to install the flue to make it a working fireplace again, they then installed an electric one at some point, the fire place is currently covered over.
Yes the single brick pier aligns with the solid wall below.
I would quite like to reinstate the fireplace at some point, does the way the chimney in the attic look correct structurally?
Id want more support under tne bricks to avoid the cantilever effect but i guess if its been like tnat for years it is in balance.
Maybe you could fit joists from wall plate to wall plate and mortar in blocks at 90 degrees to add further support under the hanging end of tne bricks. Or remove bricks altogether and rely on the flue, appropriately protected
Ok thank you!
Further in the survey report it is noted that:
“The downstairs wall has been removed and moved back between the ground floor reception rooms and there
is evidence of a boxed in support in place.
At first floor level above there are slightly sloping floors in this area which may have occurred
when the wall was removed, however there is no evidence of any inadequate support currently”
The sloping in the upstairs bedroom floor is by the wall i believe the remaining chimney is supported on. If there is no evidence of inadequate support why has the floor dipped there? Is this normal?
I had also planned to have a additional doorway put into that solid wall, is the sloping in the floor likely to prevent this being possible?
Sorry for all the questions.
