Chipboard or Plywood over floorboards
Status
Not open for further replies.
I have almost exactly the same job to tackle soon. My bathroom is actually not part of the victorian original house (it is in a small extension), but it still has timber floor boards as my starting point.
The next question everyone is dying to ask: -
Moz, in your concise list of steps, at what point would you put in under-floor heating??
I am intending to use something like this: -
http://www.cjelectrical.co.uk/products/aht_matting.asp
I know it is recommended for only wood or carpet floors, but I have a friend who has used it under tiles and says it performs perfectly well.
japher
hiya
take up floor boards if the joists are nice (i would spray wood preserve any way , ;) ) put down 18mm marine ply /wbp ... then underfloor heating pack ,
this is very important !!!
if they say put thinset /mud/adhesive on top do it , they may want a screed , all down to product , then tile as morm with a part flex cement based powdered thinset /mud/adhesive ...NEVER pre-made tub mix ..
tools ,
2 gorilla mix tubbs
2 buckets ,
a few good sponges ,
an electric saw or hand saw ,
tile float , (thick edge for floor , thin edge wall ;) )
grout edge tool
grout float
spirit levels , lines
markers
measuring batters ,
straight edge battens
many other tools I forgot now ..lol will add
but here goes
work out centre of room ..lol
split work area into 4 ,
mark work floor ,
then check always that the room /marked is level
dry lay tiles ,
get wife /lady partner to OK work ... A MUST !!!!!!!
you can then mix the powder to a nice very soft cream mix wetter than plaster ,
then on the batten edge you put down , a few tiles in a row with spaces up right ,not at corners as I have seen , tap down then use a small spirit precise level ...
then a buliders one on all tiles , they should be not more than 1 mm lip on a diy job I can live with 3 at most ..lol ;)
just do a quarter , then make sure they are all beautifully level :)
repeat next quarter ,
when grouting work in an diagonal sweep/clean when cleaning , ALWAY keep your sponge clean .. an if diyer use a grout finish tool ... which gives a gorgeous finish ..
once done accept praise an love from family an friends ;)
Status
