Just cut around this latch for door but how do I chisel out the bend?
??? The OP asked, "how do I chisel out the bend" and posted s picture of a radiused end keep... Forstner bits have a very small centre point, spade bits can often be reground to minimise the centre point size and in any case we are talking about drilling down only the depth of the thickness of the plate, or circa 2 to 3mm. The "socket" for the keep hole and the rest of the waste would be taken out with a sharp chiselThe correct size bit would have the centre in the hole so not viable , ( which would require drilling before the catch hole )..
What shape is the top cover?
Radius of bit would put centre point in fresh air and he doesn't need a round rebate despite thinking he does.See my reply above now he has found the entire catch and surface plate.??? The OP asked, "how do I chisel out the bend" and posted s picture of a radiused end keep... Forstner bits have a very small centre point, spade bits can often be reground to minimise the centre point size and in any case we are talking about drilling down only the depth of the thickness of the plate, or circa 2 to 3mm. The "socket" for the keep hole and the rest of the waste would be taken out with a sharp chisel
Original question was obviously flawed, well it was for me .Yes, but the original question was about radius end ironmongery, and we fit a helluva lot of that these days (for example there's one 40-odd storey apartment block I know of where they originally specified radius end locks and keeps throughout). If he didn't pull all the gear out of the packet........
