Choosing a correctly sized boiler
13 Jan 2019
Hi folks
I realise there are past threads covering this but I'm still confused by the subject.
In a nutshell, I moved into a property with a 35KW Glow Worm Combi boiler. My brother in law is able to obtain a very low priced 30KW Worcester 4000 Combi boiler. I'm tempted as my Glow Worm is very long in the tooth. However, I feel I'm getting mixed messages regarding appropriate sizing.
Some specs relating to my property (not sure if all relevant):
- Mid terrace stone house, circa 1830.
- 3 bedrooms
- Four floors (basement and loft conversion) with boiler located in basement
- 2 bathrooms
- 2 adults, 1 child
- 11 radiators (2 of which are bathroom towel rail type)
- Flow rate from mains water around 14 litres per minute
- No need for two showers operating at the same time
My question is would the Worcester 4000 be sufficient? I've received advice against the Worcester in that, because of the distance from the boiler to the furthest radiator, I'll need at least 35kw powered boiler. Additionally, the Worcester has a flow rate of 12.3 litres per minute, which is under the flow rate from my mains, which is also apparently an issue (but I don't know why).
Any advice is much appreciated.
Many thanks.
