Hi
Last week "dean7445" explained to me about how to work out what new boiler is best for the "flow rate".
I have added up all the current radiators, including additional radiators as there might be a change of
property layout upstairs.
That is I've added all BTU's and kW's
The reason for this post is to ask what boiler should I go for BECAUSE they are both close to the wire
regarding the flow rate - but one boiler output might struggle and the other fits comfortably.
So my flow rate is 12 litres per minute.
Total KW for all radiators = 36,044kW
Total BTU for all radiators = 123,062 BTU
Both of the following boilers are the same for Central heating output: 30kW
So I'll reduce the amount of radiators or BTU to go no higher than 30kW
(i.e. knock off over 600kW across the rads (down from 36,044kW) )
Here are the two boilers - which one would you go for.
I'd prefer to throw a small amount of money down the drain ever time its working,
if it means the boiler will not struggle OR be right on its limits every time is fires up.
Greenstar 29CDi Classic
Domestic hot water flow rate: 12.3 litres per minute at 35 degree temperature rise
(provided adequate mains pressure is available)
Designed operational flow rate 11 litres per minutes at 40 degree temperature rise.
Greenstar 34CDi Classic
Domestic hot water flow rate: 14.3 litres per minute at 35 degree temperature rise
Designed operational flow rate 12 litres per minutes at 40 degree temperature rise.
So I'm confused about;
Domestic hot water flow rate -VS- temperature rise -VS- designed operational flow rate
Many thanks in advance.
Stephen
