No difference really other than 12mm is no harder wearing and not appreciatively any different under foot than regular 8-9mm.Anyone got any views on difficulty of fitting 12mm compared to 8mm please?
If I could afford quickstep i wouldnt be fitting laminate at all, I'd be fitting engineered wood as it's priced similarly.Seriously, if you are looking for a whole house in laminate and can't afford quickstep then I wouldn't do it. Cheap laminates don't last, and you will get wear through in the high traffic areas.
Why would I use Quickstep when its the same price as engineered wood? If I could afford quickstep Id use wood. Whole point about doing it in laminate is that its a more budget friendly option, hence looking for a price of £15-20 per sqm. Traffic loading won't be an issue, probably ever, its a normal semi detached house not an airport lounge. Its just got to look nice, so...what plank width is better?Do it once do it with Quickstep. You will be glad in the end.
Quickstep will far out perform similarly priced Engineered wood.Why would I use Quickstep when its the same price as engineered wood? If I could afford quickstep Id use wood. Whole point about doing it in laminate is that its a more budget friendly option, hence looking for a price of £15-20 per sqm. Traffic loading won't be an issue, probably ever, its a normal semi detached house not an airport lounge. Its just got to look nice, so...what plank width is better?
Each to his/her own, but I wouldn't recommend laminate for bedrooms.
1) Beds slide around, even when fitted with castor cups,
2) It's uncomfortably cold for bare feet.
But you wear a scarf indoorsI got rid of my bedroom carpet 10 years ago in favour of laminate and I do not have either of those issues.
My double divan is on sliders and it still does not move unless deliberately pushed sideways.
I do not own a pair of slippers and have never found the laminate flooring too cold for my feet.
Have a look at lvt as well.
