Before I start, I would like to say that I'm a bit of a novice with this!!
I need to extend some pipework for a wash hand basin. I believe the existing pipes are 15mm, so I bought more of that, plus various compression fittings to allow me to do the job.
Even though the new pipe and all fittings are 15mm, when I tighten the compression joint, the pipe slips out. The nut and olive aren't dead tight on the pipe.
Should I use PTFE tape to make everything tight, or is there something else I should be doing?
