unfortunately dicky thinks everything that was done 30yrs ago is still the best thing to do today. If you use decent copper olives you dont need jointing paste. Its the rubbish quality brass composite olives we get now that are the problem, a bit of jet blue is my preferred route but its really not a big deal what you use as long as it dont leak and its approved for the situation, which as pointed out boss white is not for potable water, and its not a generic term, nonsense. You tell someone to buy bosswhite they will buy bosswhite duuuh !!
Blimey, we'll be putting Airfix glue on Speedfit joints next.
As for unions, again face to face metals need joint paste. Oh you can read all the manufacturers drivel you like. But Real Plumbers use Boss White or the likes.
Eh? Thats funny, on all the back boilers I service over the years with a union connection to the gas valve, never once have I seen one with paste on the union joint, and they are obviously gas tight.![]()
Thats hardly the point, you advised using something you shouldnt in the situation. Now your trying to dig yourself out of it and making yourself look foolish.As for the trade name Boss White, again who cares if some DaftyDIYer puts Boss White on fittings of wholesome water pipes
er no they don't, can't actually remember the last time I had a leak on any fitting let alone compression tbh, but then I always swap the olives out for decent quality copper ones. How would you even know if by your own admission you never do it? As usual you only know what you know, and what you know is best. Your very narrow minded, but thats typical of a lot of old school plumbers who think they know best, because its always been that wayYour compression fitting will leak if you don't use a joint paste on the olives!!
I wouldn't know I don't buy cheap compression fittings, maybe we've just found out why you need all that boss white?Most cheap compression fittings have copper olives anyway.
I did work for BG yes, long time ago now. Not sure what the relevance is though.Again, your knowledge is found wanting. I thought you worked for BG son? And spent your day with a FGA probe up some old dear's flue??!!
Sussex???!! The water pressure there is pizz poor, in fact you're on a hose pipe ban there son. Lucky if you've 1 Bar water main pressure?? The compression fittings could be hand tight & still not leak!! So take it from a Real Plumber, joint paste on every compression joint, even with your pizz poor Engerlander water pressure.
Have you got a LPG ticket mate?? Or do you just fan.y around with Nat Gas?? Not that anyone was debating gas, when was the last time you were at Vision Express?
Just popped some ptfe tape on the olives.
The 15mm fitting fits snuggly on the pipe with no play at all.
The 22mm doesn't fit snuggly so I suspect may be imperial. It's been on there for a week so I don't feel the need to do anything about it immediately.
What next?
