My daughter has just purchased a flat. The consumer unit is new and the wiring is part 16/17 edition. The ring main which has 8 double MK sockets keeps tripping, I would like to point out that all the all the sockets are new.
The ring main has been wotking fine, she has had very little connected to it before this fault. The circuit breaker which is 32 amp will not stay on, if you switch this to the on position it then trips the RCD ib the consumer unit.
Any advise as to tracing this problem would be very much appreciated.
Thanks Crunep
Thanks Crunep
