Citroen C3 Sensodrive Gearbox Problem
12 Aug 2011
Lancashire
Anyone had any experience of Citroen Sensodrive Gearbox problems?
Mine has had a new clutch, clutch actuator and gearbox actuator - all citroen replacement parts.
It now drives superbly when going forward, but it has a problem with reverse gear.
When cold it selsects reverse with no problem 99% of the time.
However, once it's warm it won't select reverse, although sometimes you can hear it trying to select the gear.
I've had it back to where all the parts were fitted and they say that all is working correctly and I've had a look myself and have to agree that would appear to be the case.
I've had an auto electrician out and he said there was no fault code, although that could be the machine he was using.
Anyone got any ideas ?
I need someone with experience of these boxes.
:confused: :confused: :confused:
