An interesting one, if I'm understanding it correctly.....you say that the clutch pedal won't return on its own, but if you pull the clutch arm back, the pedal rises...thats about fair enough so I guess the problem is in the clutch itself - maybe a collapsed release bearing.
Please post back with the findings!
John
Hi John,
Just got my car back today; took two and half weeks for them to fix it. They replaced the clutch and then also another few parts.
One of the parts that they showed me when I went to pick up the car was some sort of lever, circular at one end and narrower on the other. The circular end looked as if it fitted on a cog wheel type part. This had snapped (and therefore wasn't providing the grip that it was meant to). They stated that this part broke AFTER they replaced the clutch - it meant the clutch pedal wouldn't return to its position after being pressed...the same problem for which I tool the car in.
This little part was in on the gearbox side - linked to the gear mechanism.
I feel as if they replaced the clutch when it probably didn't need to be, and then realised the real fault and fixed that too.
They are a national chain and charged me £250 - this was for a clutch replacement, and the other stuff was done for 'free'.
