- Joined
- 19 Nov 2012
- Messages
- 2
- Reaction score
- 0
- Country
My van has similar symptoms,havent been able to start it since a 1 month lay-up.The only thing out of the ordinary was a slight loss of power or hesitation on acceleration and a tendency to need a bit more cranking to start.At the time I put it down to a lazy starter or engine wear(192000 miles),now though it refuses to start.Preheating circuit is tip top,lift pump ditto,Im getting crank sensor signal,pressure in the rail(not measured just observed by cracking open the high pressure feed to the rail).
The afore mentioned hesitation could be relevant,a mechanic friend suggested the injection pump could have a worn or leaky piston or the pressure regulator is faulty.My next step now is to take the pump to a diesel injection specialist and have it tested.The system on my van is the Bosch EDC15.
I finally got the engine going after a lot of trial and error.
The main problem was a worn injection pump not generating sufficient pressure.I fitted a pump from a 306 hdi with 90000 miles and it started on the first revolution! Once it was running I found power was very reduced a leakback test showed no 1 was passing ,since the engine starts on no 1 every time,this was also adding to the non starting.
One refurbed injector later I have put up 4000 miles with no problems,she`s back to full power, just passed emissions with flying colours .
The wear in the pump is unusual-I always use branded diesel,none of that supermarket stuff so i guess I was just unfortunate.
