Walk away or this job would come back and bite you!
Andy
Andy
Upvc won't be good cut so short in the reveals surely, some kind of wood cladding? What would you recommend? White of course.i had assumed txg cladding ----now you have me thinking i may be wrong
the reveal at the door looks tight at perhaps8-12mm
I wonder where the leak is coming from?A surveyor has looked at it and can't find the cause. There's a downpipe directly above it though
So use 2mm in reveal and the white upvc T&G cladding on walls? Don't bother with wood even though it's interior?you can get something like 2mm white acrylic that may work in the reveal
Lol. Can't believe surveyor missed downpipeI wonder where the leak is coming from?
Yup, t'is a real chin scratcher, this one.
Guessing from the windows and doors, this could have been an external wall, there might also be some water penetration into the cavity; this may explain the spread of dampness over the door lintel?A surveyor has looked at it and can't find the cause. There's a downpipe directly above it though
You could make some of these suggestions to the clients, you may be able to solve the problem, when a surveyor couldn't!Lol. Can't believe surveyor missed downpipe
All we need now is DIYNutJob for the perfect triumvirate!Kettle and tell - what a double act
as its a "butter up" compromise and should only ever be temporary, you need to work out the expected time span before doing it properly and choose the minimum spend to get the best maintenance free Finnish and go from thereSo use 2mm in reveal and the white upvc T&G cladding on walls? Don't bother with wood even though it's interior?
