Exactly - and you know as well as I do that virtually none of the people to whom you so often direct such questions/comments ever will do any proper testing. You also know that virtually no electrical work can be done 'properly' without that testing. So, given that the required proper testing would almost never get done, do you see the only role of this forum as effectively being to try to persuade people (very rarely successfully, I suspect) not to undertake DIY work?Have you counted how many times I've asked people what they are going to do about testing? How many times I've asked them if they know what tests to carry out in what sequence and at what point they would energise the installation, and for each test if they know what is being measured, why it is important, how to carry out the test, and with what equipment, and what sort of results they would expect to get if everything was OK? How many times I've directed them to read this?
How many times when they pop up after the event I've asked what their test results were? DIYing is optional. Equipping yourself with the right knowledge and the right tools is not.
Kind Regards, John.
