Ok, narrowed it down a little. Took injector cap off (single point injector above inlet) Tried to start her and big jet of fuel comes flying out of the top of the injector - so fuel line ok.
Removed injector, load of fuel had collected in and around the injector - (is this normal???) - this trickled down into the inlet when I pulled the injector out.
Tried to start her again, fired up for a few seconds (w/big puff of smoke coming out of the hole) Assume this was just the excess drained fuel burning off, and that the smoke is nowt to worry about.
So she fires with fuel in the hole but doesn't sustain...leads me to think that injector isn't erm...injecting!
So borrowed another injector from other vehicle. Same injector, same part number......Same problem!
So initially it would appear that whatever controls the injector opening and closing is not doing it's job, however I don't know what that is
Possibly the ECU? Problem with that is that it resets itself every time you change the battery, and I keep having to switch between 2 batteries because they are wearing down v/quickly trying to start the bugger.
The little pin at the bottom of the injector depresses slighty when pushed, I assume it doesn't actually need to travel that far to do it's job?
There is a spec for testing the inj. with a multimeter, it says it should be 1.2 to 1.6 ohms, however I've no idea what the MM should be set to in order to get that reading (electric/tronics not my strong point
