Cleaning Brickwork prior to applying Stormdry
21 Aug 2021
Hi
Can I get some advice please - I've had some work done on the front of my house to fix an issue with water ingress. I now need to paint it with Stormdry (Water repellent). I have two questions I would appreciate your advice on please:
1. What can I clean the blackened brickwork with? I've tried Spear and Jackson spray and leave but it doesn't seem to have done anything.
2. Is there anything I can do to make the new bricks/pointing blend in better? Or will it do so over time?
Thanks in advance
J
Just need to clean the best you can then treat.
You can hire a jet wash or get a company in but you need to be careful not to damage bricks.
Damp surveyor suggested it - Stormdry still allows the bricks to breathe.
Since brick houses, well designed and built properly, don't require additional surface coatings to stay dry, it does beg the question why yours needs it.
I'd use a DIY pressure washer, with the gentler fan jet - not the cone one that is a spinning needle jet. A DIY one will be reasonably gentle, a hired or commerical one might be a bit too hefty. If you're stripping the surface then stop.
Lots of people recommend StormDry, but I don't know how many are sponsored by them.
I used something similar on my previous house, it worked very well.
If there's green or black staining within the brick after washing then it needs chemical treatment to kill the moss or whatever's growing there. Let everything dry before StormDry, probably not the best time of year for it now.
Storm dry is a bit of a marmite thing on here.
It can be useful, I have used it on the top chimney flouncing mortar and after repointing the chimney I used it only on the mortar and some bricks that had a top facing the sky. I also used it after I had redone some valley mortar and I used it on the ridge tile mortar. But I would not consider it for painting all the brick face.
