Whenever the thing crops up - ask how much global temperature will be affected by changes in your life style !
Just for fun...
An exploration in moving from CO2 emissions to atmospheric concentrations CO2 to global temperature changes C°...
The gist...
From observational data it can been shown that from 1958 - 2006 when dividing annual emissions CO2 in Metric Million Tons (mmt) by annual CO2 concentration changes Parts Per Million (ppm) there emerges a relatively flat average of 14,138mmtCO2 / 1ppm
Over the last one and a half centuries atmos' CO2 has increased by approx' 100ppm from ~280 to ~380ppm..
Global temps' increased by ~0.8°C over same period.
100 / 0.8 = 125ppm per 1°C increase, a reasonable ball park figure... as we'll see later **
So to shift from mmt emissions to temperature change
~14138mmt/ppm x ~125ppm/C° = 1,767,250mmt/C°
UK in 1990 emitted 212 million tonnes Carbon or 776 million tonnes CO2 Note, most real data I have found relates to Carbon and not CO2 itself, so watch out when some begin swapping between the two to suite their 'wow' factor (3.67) takes place - Brown's territory!
If we reduced the above UK output to zero - zilch - nowt.
** The approximate global temp change could be 776mmt / 1,767,250mmt/C° = 0.000 439°C
Or a meaningless 4.4 ten-thousandths of one degree C ... even with the best will, calibrations 'nall (not too many of those no doubt) - measure that !!
We aim to cut that output in reality and by some obsfucation (C trading?) from 776mmt to 500mmt by 2020... A reduction of 276mmt p/a or 276 / 1767250 = 0.000 156°C around 1.6 ten-thousandths of one degree C.
In UK, 'offsetting' 9tonnes CO2 emissions p/a av' per tonne £8.80
But 1 tonne responsible for temp increase of 1 x 10^-6mmt / 1,767,250mmt/C° = 5.7 x 10^-13 C°
So the cost of 1°C = (5.7 x 10^-13)^-1 x £8.8 = £1754 trillion give or take a bit! Mind you that 1° AGM could be just another illusion...
