I have an annoying "clonk" noise when I use the hot water from my basin mixer tap. I don't get the noise when using cold water. The mixer tap has 2 fairly long flexible hoses supplying the hot and cold water to the tap. When the tap is turned to the left for hot water and it is then closed firmly, I get a "clonk". I can feel the "clonk" on the flexible hose but can not isolate where the noise is coming from.
Attached are photos of the flexible hose and the tap (hoped to upload a video but have been unable to).
Any suggestions greatly appreciated. I am tempted to replace the hot flexible hose but can't really see why this would be causing the noise. I do have separate isolation valves just before the flexible hoses are connected.
Thanks.
Thanks.
