Hello,
I have recently converted my garage to an office. It's been built with cavity wall and 100mm insulation. I didn't hire an architect as wanted to save money.
The house was extended before we bought it and it had a 1st floor extension above the garage, this included having a steel beam half way into the garage to take the load of the extension, this beam had a 3 brick thick column built into the cavity wall to support it. I have continued the cavity wall along the outside wall, insulated, plastered etc and now realise that the column is a cold bridge.
I presume I really have to remove the plaster and put a section of insulation along the entire wall and then replaster.
If I don't I am guessing it will get wet and mouldy?
The good news is that I get to practise plastering again...
Thanks,
Jamie
Thanks,
Jamie
