I have an ongoing problem of hot water seesawing into the header tank
when the central heating pump is either switched on or off (not a problem
whilst it is actually on!)
This is causing a build up of sludge in the header tank which in turn is
damaging the boiler heat exchange.
Initially I supposed that the header tank was not high enough above the
pump (1.9m) - however, I then got to thinking why the problem only
occurs when the pump switches off or on? Surely if the static head isn't
great enough then the problem would occur all the time the pump runs?
the pipe arrange looks ok to me (see below), the pump is on minimum
(no. I), the system is microbore.
Has anyone any ideas - I have called several plumbers, none are interested
in small jobs and won't even come out to look.
I am more than happy to change some pipe work - problem is knowing
what to change! lift header tank, change pump, change pump position
if so where to, or perhaps all the above.
