I have a cold radiator.
My system is run off a Bosch greenstar 35di combi and the radiator in question is piped up with a lsv at either end (no trv).
I have checked over the sytem and ascertianed the following -
1. every other rad heats up fine and the system is not airlocked.
2. The flow into the rad is fine and the lsv is fine
3. The return from the rad is fine and the lsv is fine.
I think that the problem is a blockage in the pipework between the return lsv and the return main pipework.
Question is can I use a restorer/chemical to try to unblock this.
I have a mix of copper and hep20 pipework throughout the system
How much would I need and how long do I leave in .
Thanks in advance
Allan
Thanks in advance
Allan
