First of all let me say that this is a brilliant forum. I have been able to resolve many issues by it.
The problem i am having now is that we have moved to a new house with a large open plan kitchen and conservatory. It was brilliant in summers but has been freezing in winters. The problem is that the radiators in the conservatory only get luke warm. There are two radiators. I have tried the following.
1. Drained the system and re fill it.
2. Drained the system till it ran clear, put cleaner in it and run it for 2 days and then drain it and refill it by adding the inhibitor.
3. Closing TRVs on all other radiators and then checking the conservatory radiators which became really hot.
4. Balanced all the radiators.
5. Turned down the feed to minimum on most radiators.
The result has been only a few degree increase in the temperature of the radiators. They are still luke warm. I can feel the feed pipe to the radiators and can say that it is really hot but not as hot as compared to the feed on the lounge which is next to kitchen. The return pipe is same as the room temperature.
What could it be? My guess is
1. Pump? Less likely as its perfectly heating all around the house.
2. Heat loss? Could be the case but as the pump is on full speed surely it should outflow the heat loss.
3. Lack of return? Dont know may be gravity is playing some part in restricting the flow?
It has made the kitchen useless as well as it is freezing in there.
