I have a cold water tank in the bathroom.The other day I noticed water coming out of the overflow so went out and bought a new valve and float.
Bent the arm to the same angle as the old one and fitted it.
Turned the water back on and the tank filled to about 2 or 3 inches below the overflow and the valve appeared to shut off.
On saturday there was the sound of water surging and then stopping repeatedly coming form the tank as it refilled after running a bath.
This morning I see a damp patch on the ground below the overflow.Had a look in the tank and the water level is above the overflow outlet and the float is submerged completely.
Faulty valve ?
Faulty valve ?
