i'd keep the Radiant boiler if the aternative was a Poxy Batterton heap i would not sell a potty boiler to my worst enemy
just as a good example of their rubbish went to a performa 28 last night - no water pressure in system - refilled - switch on - nothing - reset still nothing fault code on 70 degree light - dismantle pressure differential and check diaphragm - put back in - reset boiler - fan runs 3 seconds - fault code on 30 & 50 reset fault code 40 give up and go home
this morning back to it reset runs normally for 20 minutes then reverts back to fault 70 no amount of reset will get it going - ring poxy's technical did pcb get wet he asks, no i reply but to be on safe side take pcb out and check- no water evident ring twits again check temperature sensor he says and if its 11mg ohms or less its the board!
will see on monday if he has cost me a BOARD !
NEVER will i ever fit any of that groups products ever again.
