I have a Baxi 105e combi boiler, around 10 years old. Does a good job of warming the house but the pressure drops fairly regularly, and I have to top it up to 1-1.5 bar at least weekly.
I noticed a slight weep and a bit of rust around where the heating return is and assumed it was that. However today I have had the heating on and witnessed hot water dripping out of the 15mm drain outside. The pressure is above 3 bar when it is running.
I've been having a mooch on the internet and read about a pressure relief valve possibly at fault, is this a possibility? Or perhaps it is doing its job and dumping the water as the pressure is so high. Is the fault elsewhere, whatever is causing the high pressure?
Any advice? TIA.
Any advice? TIA.
