Bear with me - this may be a long story/question.
Firstly, boiler is a Ravenheat RSF 100 which is about 2 years old.
Recently we have had a loft extension and had two new radiators added which all worked fine.
Anyway, last week the hot water stopped working properly - ie it ran hot and then cold, then hot, cold etc.
Man came to look and said needed a new thermistor which he fitted. (Imbetween his diagnosis and fix, the pressure dropped to 0.5 bar).
As he had added water to system (to get pressure right), he said there may be air in system in which case bleed the radiators. This was true as the 2 in the loft were cool. I bled them both so they were nice and hot and then noticed the pressure had dropped back to 0.1bar. I added water to get the pressure up to 1bar, but after about 1 hour it dropped back to 0.
Wondered if there was a leak of any sort and discovered water on the ground outside behind the boiler.
Phoned boiler man again to be told probably the safety relief valve and he will come again sometime(!)
Both the heating and hot water are fine now.
My questions are - is this anything to do with new radiators?
Could this new problem be anything that the boiler man did on his first visit?
Does his explanation seem a reasonable one, and if so, what fix is needed?
Thanks.
Thanks.
