Behaviour of the pressure switch isn't making sense.
Disconnect boiler from mains elec.
Undo the obvious screws until you can see the PCB. Bottom left is the connector for the pressure switch, two wires the same colour, yellow I think.
Unplug the connector from the pcb.
The boiler will now ignore the pressure, so it'll light. What does the pressure do? It should be 0.7 - 1 bar cold, a bit more hot. The pressure switch should only come on below about 0.3 bar though that varies.
Don't leave the switch disconnected, because it's there to protect the boiler if the water goes too low.
