OK - here i go !
I have just moved into a new house and have found myself confronting a rather hostile heating system. I don't know much about these things - so please bear with me as I attempt to explain.
The radiators are heating very well and the pressure in the shower is amazing - BUT - (a very big but!!!)
- some of the radiators keep burning even when the thermostat is down to 10deg.
- On turning off the radiators i notice a couple of drops dripping from the valves on the sides of the radiators.
- the 'overflow/safety' pipe (which opens in the conservatory!!!) keeps dripping.
On looking inside the airing cupboard i noticed 2 red cylinders - and a water tank. (no labels of make!!!) but the pressure gauge had the black needle at 2.5 and the red one at 2. (which to me means TROUBLE!).
There is a boiler in the garage with 'Potterton' and 'suprima' labelled.
I believe I have a high pressure combi-boiler system.
I did discharge the pressure by turning a safety valve - which turned the conservatory into a swimming pool - and then I opened the valve to set the pressure back to 1. all seemed fine but 12 hrs later there was a puddle in the conservatory - from the overflow pipe.
Does anyone have any ideas what I need to do - or what am i doing wrong ?
I have tried turning the 2 valves in the airing cupboard to various positions - but no luck !
I have even called plumbers in - who have marvelled at the 'system' - but not given any useful solutions. One of them wanted to change ALL the valves on the radiators - saying they were substandard and causing the trouble !!!!
HELP !!! please !
HELP !!! please !
