Gas wizard. Please explain your comment about viessmann and 7% co2.
I will have to consider using an inferior boiler and set up so as to avoid condensing as much as possible I guess.
There you go sinking down to sarcasm again. Dan you really need to grow up. The viessmann in my opinion has the best weather comp. It's pretty much the only boiler I ever see fitted with it. Vaillant tell me there's dosn't work properly and Keston on there training course said it doesn't work. I'm not sure about ATAG they are a difficult Boiler to specify and I don't specify any boiler with aly in the heat exchanger. I've not heard anything bad about Intergas and know nothing about them. Every engineer I've meet that understands weather comp fits Viessmann, I what to talk to any one who uses weather comp on any other make and see if there's anthill better out there, so far once not found anything better. What is your boiler and how does your weather comp work? How easy is it to fix? What % of it's time is spent condensing? I'm here to learn, teach me, sarcasm and negativity achieve nothing.
