I thought that a combi boiler took a cold feed in and then had a cold feed out so all hot/cold water (for taps) passed through it. Am I mistaken, or do different manufacturers do it differently?
I was looking at the Vaillant 838 install manual and noticed they only have 5 connections; CH flow, hot, gas, cold, CH return (plus the filling loop).
If the cold taps in the house are fed directly by the incoming mains water do I need to give any consideration to where on that circuit the boiler gets it's feed? Should the boiler be the first connection off the incoming mains, or does it not make any difference?
Thanks.
Thanks.
