What is the charge time recommendation from empty to full or first charge?
I would put it on charge for a good few hours and then try again. A drill like this should make better progress than you obtained.
Twenty two mins. Its the makita lxt bhp453 combi and I agree I should definitely be getting a better result than I am. I'm sure that certain types of brick can be harder than normal but surely when a drill is sold to be able to drill through cement/ brick then that's what it should be able to do?
22 mins That's bloody quick.
Are you putting a bit of pressure on the drill when drilling?
Put a bit of weight behind the drill and push against it with one hand against the back of the drill.
I didn't put any pressure initially as the manual is full of warnings not to and I do as I'm told. but I got increasingly more desperate and did put some pressure on but nothing much appeared to happen. The dust was minimal and the hole left was only a little ' un.
