Hello,
I posted some time ago about which boiler would be best. I have since upgraded the water coming into the house to 32mm mdpe and my flow rate has improved a lot.
I have a static pressure of 3.6 bar. I have a flow rate of approx 30lpm. (this was tested by running 2 taps (bathroom) at the same time. For 30 seconds, I had 15l of water total. If running just the bath for 30 seconds I got 10 litres)
I've been looking at this boiler
http://www.bhl.co.uk/product/VAILLANT_ECOTEC_EXCLUSIVE_838_HE_COMBI
My plan was to use this for the CH (direct cylinder). It would also provide hot water for the downstairs taps and possibly 1 of the ensuite bathrooms. The cylinder would provide the rest of the hot water for bath/showers etc.
My questions are,
What is a good unvented cylinder?
Is the boiler a good choice?
What size pipe should I run to the cylinder/hot water. I was going to take 1 28mm pipe to the bathroom, then branch off 22mm for bath/shower cold, then another 22mm to the cylinder. Is this bad practice? Should I run 2 seperate 22mm pipes.
My questions are,
