I also thought this, He could be correct, if the flow rate was 20lpm or similar, and the boiler is "clever" enough to figure it can use 12lpm from the combi and 8lpm from the tank. I doubt this is the case though.
Thats exactly how they work...
yes recirc loops can be wasteful...
Interesting. So with my 30lpm flow i'd be using 18lpm from the tank, so I would get a true 10 minutes out of this boiler. About the same as I will from the 300l cylinder.
Could I do it so I had a cylinder and combi on the same circuit? Would this work? Its pretty unorthodox i'd imagine, and it would depend on the balance of pressure between the 2 I guess.
Today i've cut out 100 meters of old copper. 30 meters of which was 15mm to the shower! No wonder the shower was pitiful before! (electric)
I've just found another issue. I knew the "loft space" wasn't high, The roof's a low pitch, and the upstairs rooms have very high ceilings, (2.9meters) but the roof cuts into the rooms, so they are lower at the edges. the result is a loft that is 1.6 meters at the highest point. Realistically the tallest cylinder can be around 1.4 meters which rules out anything over 200 litres it seems.
However, I'm thinking the best way is to run 2 smaller cylinders. (unless you can get some horizontal ones?)
I could be miles off here but...
If I run 2 cylinders the advantages are, twice the coils.
Better distribution of weight (the house was built in the late 1800's) and until recent improvements wasn't the most structurally sound.
The other thing is put the cylinder into a room, or go for the Glow Worm.
Disadvantages. Cost to run and install.
My main concern is the balance. If the first cylinder has a slightly higher flow. All the water will be used, so the water would drop in temperature while the other cylinder still has hot water it would only be flowing slowly.
Can you get a controller, so when the water temperature at the output drops it reduces the flow or turns off the cylinder?
Thanks for putting up with the long/thinking out loud posts.
