OK, I know some of this,
How many people live in your house? >>2 adults<<
Do you prefer baths? >>No<<
Do you prefer showers? >>Yes<<
If showers, low pressure or power showers?>>I have an electric shower<<
What is your water supply pressure? >>Not sure, but it seems OK<<
What is the flow rate at peak demand times? (Not your peak demand, but at advert time during Coronation Street) >>Seems to hold out OK, bounces back out of washing up bowl all over the work tops - is that a bit technical?
Have you thought you will need a water conditioner to reduce scaling of the DHW heat exchanger? Yes I have read about this being a problem on Combi's, what is the rough cost of one of these?
Thanks for your thoughts, this is driving me mad as I can see the cost\time savings up front for the combi solution, but am looking a bit longer term but am not sure of reliability, which is important. I think my DHW (I learnt a new TLA!!) usage is low, certainly with multiple devices at once, ie washing machine \ bath (Rare - prefer showers). However I don't want to be calling on your professions services too often. I have a conventional setup in my current house and it has been (touch wood) fairly fault free during last 12 years, fan burnt out 5 years ago but that was easily tracked and fixed.
Bottom line I guess is, time savings upfront versus long term grief?? I really was hoping the industry had got on top of the combi boiler solution, it has been around for some time.
Cheers
